Went bonkers
After "Christmas" was over on my dash it started up again intermittently so I pulled over (of course) and let the car sit for a bit. Started it up and everything was fine. Drove home with no problems.
Can the PCM "hiccup" like that sometimes?? I have had Hypertech PPIII and Vince Crane (to eliminate the skip-shift) programmed-in but it's been 3 years since I did so. I did move from an altitude of 7200 ft. to 5800 ft. just recently. Everything seemed connected well and the belt was fine.
Also, what is the solution to the rear-defog/power seat fuse dying occasionally? Do I just replace the fuse? I believe it's a common problem, as they're both linked. Using the rear-defog button it goes out and then the seat and rear-defog are dead for about 2 minutes.
Mike
pls.email response to mikecronis@mikecronis.com
Another post I found:
https://ls1tech.com/forums/pcm-diagnostics-tuning/593876-really-odd-electrical-problem.html
Drove the car the next day and did not have any problems with it. I then decided to drive it to work today as we are all planning a trip to the track after work. Car drove fine for the first 10-15 minutes and then the radio shut off and I noticed the gauges were going crazy again. This time it only lasted for maybe 5 seconds and the car never died. I was able to get to work (another 10-15minute drive) without any additional problems....
Any ideas what is causing this? I checked the battery connections and the ground, but they appear fine.... Should I not risk going to the track tonight?
Thanks,
Kevin
Also, as a quick fix, I was going to try to add a new ground from the battery to the front passenger side of the block. There is a nice little bolt hole there. Any thoughts on this?
Thanks again,
Kevin
Thanks for the feedback!!!
