Problem with Tunning or Transmission????
I send my pcm to pcmforless to get a tune after all my bolt on mods. Mostly to get the tune for the long tubes and nitrous.
Now the only problem is when I try go wide open throttle on first gear it doesn't shift and just bounces off the rev limiter at 6500.
I have a stock motor and a rebuilt transmission that has been running great, untill now.
Could it be that the shift points are messed up?
mine was doing the same thing.
I told him not to mess with my shifting BUT he did, stock offset was 10 he bumped them up to 127 and raise my pressure up from 90psi-120 psi.
Its funny because he ask you want you want and it looks like he gives you an off the shelf tune...
I pretty much been doing my own tuning
