hpp3 code 6 help
Old Sep 21, 2006 | 06:47 PM
fbody guru's Avatar
Default hpp3 code 6 help
during the tune the battery died and now it will not continue the tune. keep getting code 6, if this reappears call hypertech. has anyone ran into this? any help? thanks
Old Sep 21, 2006 | 07:22 PM
98noscamaross's Avatar
We ran into the same problem with the battery going dead, Your best bet is to throw it away, it aint worth the cost of sending it back to hypertech to be fixed, i think they wanted $150 to fix ours, so we just tossed it instead.
Old Sep 21, 2006 | 09:50 PM
fbody guru's Avatar
did you have to do anything to the car? because now mine wont start.
Old Sep 22, 2006 | 10:47 AM
fbody guru's Avatar
I called hypertech today and they it basically scrambled the memory in the car and the programmer. they have to have me to send them the programmer and the ecm from the car to try and fix it after i have it reflashed along with proof of purchase which i cont find after 3 years. do I have any other options?I really dont want to use hypertech any longer.
help please
Old Sep 22, 2006 | 01:59 PM
2001NBMZ28's Avatar
Have you tried calling your dealer yet? Hopefully you can remove the PCM from the car (vs. having it towed in) and have them reflash it to a stock tune.
Old Sep 22, 2006 | 02:30 PM
slow's Avatar
The flash chip most likely need to be removed from PCM and recovered on a chip programmer.
Not much fun, hope you have a GOOD soldering station, since these 44 pin flash chips are not fun to solder.
Ryan
Old Sep 22, 2006 | 02:35 PM
fbody guru's Avatar
had to have towed, but havent heard from them yet.I just know im not going to like what they tell me though.
thanks for the input.
Old Sep 22, 2006 | 03:14 PM
fbody guru's Avatar
just as i thought. they said it couldnt be reflashed and i need a new pcm
Old Sep 23, 2006 | 05:38 AM
fbody guru's Avatar
thanks for all the input lol
