I called Bosch tech re: slow oxygen sensors
#42
I installed the second new set of 13111's. I ground down the driver's side (bank 1) bung about 0.250", but I left the passenger side (bank 2) as it was.
After putting around 20 miles on it, during a short cruise I viewed the sensor voltages. They are both switching quickly from ~100 mV all the way up to ~800 mV. No codes yet! Fingers crossed!
FWIW, so far it seems as though grinding the bung down has had no effect.
#44
so what kind of headers are you guys with the o2 switching codes using? I have pacesetters and havent thrown a code yet and its been a few years, and I even have home made O2 extentions (butt connectors).
#45
Update: Since the new 13111's went in I got a few slow response codes on bank 2 sensor 1. And last night I got my first insufficient switching code for that sensor.
Today I plan to grind the bank 2 bung down, like I did to the other side. There might also be a small exhaust leak over there.
Frustrating stuff!
No problems on bank 1 so far, knock on WOOD!
Frustrating stuff!
#46
LS1Tech Sponsor
Frustrating stuff!
Frustrating stuff!
Did you check to make sure 5v's was feeding them?Next would be the grounds.
#47
Originally Posted by Slowhawk
Feel free to stop by my house whenever and I'll check it out on my scanner on how quickly they switch.
I did not measure for 5 volts. I'll do that next time I'm under there. Is the 5 volts for the heaters?
I have checked all the grounds, they all seem ok.
FWIW, there was a small exhaust leak right after the bank2 sensor, I think I sealed it up.
I'll go for a ride tomorrow and hope for the best.
#49
i have been monitoring mine, and it seems that only after i got WOT did it throw a code. i monitor my car everyday just about and the AFR is just where i want and everything else is good. it used to do it from stop light to stop light.. now it seems as if it comes on (SES) soon after WOT and decel
#50
I have that problem and cant seem to resolve it. I went and bought the new sensors and got the code immediately. I did not check for the 5v, or ground. How do I go about doing this?
does anyone in Arlington Tx have a scanner that can hook me up to see if they are switching good or not?
thanks in advance
thanks in advance
#52
thanks in advance
thanks in advance
#56
Originally Posted by Doc
For the love of God weld that **** up and be done with it. I am telling you your sensors are merely screaming at you to stop the leak(s).
I'll also measure for 5 volts. I hope I don't harm the PCM!
#58
I took some voltage readings from the car's pigtail. With the ignition on and the sensors disconnected from the car, I got the following:
11.5v on the black wire (heater).
0.0 volts on the pink-ish wire (other heater wire).
4.5v on the tan wire (low signal).
1.25v on the purple wire (high signal).
I don't know what to make of these values but they were essentaily the same for both banks.
FWIW. I'm sure there is no exhaust leak on either side.
#60
i just turned the freakin codes off. i know otherwise daily driving my 02's are switching fine. just every now and then they will pop that code up; so i'm just going to forget it.
i may wrap the headers or around that area and see about a difference, but when i had my stock injectors on the car and headers, it was fine for 7k miles.... installed injectors and WTF. would it take that long to pick up header change??
