Shift light install
Old Oct 3, 2006 | 03:23 PM
Bandit28's Avatar
Default Shift light install
where do you hook up the tach terminal wire up on the autometer shift lights? anyone? pcm? coil?
Old Oct 3, 2006 | 03:41 PM
GreaseMonkey83's Avatar
if im not mistaken, i think you have to install an rpm switch, i think harlan makes them...
if someone knows of another way, let us know.... im trying to hook up an electric shifter.
Old Oct 4, 2006 | 02:13 AM
BOONE's Avatar
On a 01 car its the red side of the computer, pin #10 its a wht wire that goes out towards the front where the loom goes onto the pass side fender well. I tapped in by the fender once I traced the 10 pin out and just soldered it for a good connection, then hid it in the loom. Looks stock. Just make sure you set the shift light to 4 cylinder so it will read correctly.
Old Oct 4, 2006 | 09:12 PM
can you hook an electric shifter up to that??
Old Oct 4, 2006 | 11:00 PM
SSpdDmon's Avatar
http://www.installuniversity.com/ins...ht_install.htm
Old Oct 5, 2006 | 12:37 AM
BOONE's Avatar
If its rpm activated, I would think you could. If all it needs is a rpm signal to trigger it. Ive never done this though.
