hp tuners flashing problem
Old Oct 3, 2006 | 10:38 PM
Cam72aro's Avatar
Default hp tuners flashing problem
Has anyone ever had a problem flashing a pcm with hp tuners. Its a 99 pcm, it will read, but it keeps saying failed when the calibration file is trying to load in. Has anyone ever has this problem? I dont think the vats would cause this? Is the pcm somehow locked? Do I have a bad pcm? I dont think this matters, but its in an old car. Please help me out, I just want to hear this thing run. Thanks, Josh
Old Oct 3, 2006 | 10:39 PM
foff667's Avatar
LS1TECH Sponsor
might wanna contact support, but are you using an older serial cable unit or the newer MPVI usb unit? If your using the old serial style are you using a serial to usb adapter? Any chance the obd cable might have seen its last days?
Old Oct 4, 2006 | 04:57 PM
JoeyGC5's Avatar
Make sure your car battery voltage is over 12vdc
Old Oct 4, 2006 | 07:31 PM
Cam72aro's Avatar
Default pcm
Would this happen if the pcm was locked?
Old Oct 7, 2006 | 07:52 PM
Cam72aro's Avatar
Default hp tuners
t. t. t. 4 me
Old Oct 8, 2006 | 10:47 AM
JoeyGC5's Avatar
If you can upload the program then the pcm probably isn't locked. At least the locked pcms I've tried to connect to prompted for the password before being able to download/upload, without GM reflashing. Are you getting any time out messages? Turn off any virus protection you have also.
