If you know your shit ......
Old Oct 7, 2006 | 01:33 AM
Full-Force's Avatar
Default If you know your **** ......
I had to repost this problem because I thought I had it fixed and its still not fixed.
I took the 6 speed out of my car and put a th350 in. The car has not idled worth a damn since.
Well I added a home made ram air setup and it really went to **** then. Now I dont know if the ram air made it worse or just happen to start getting worse around that time. Anyway here is the problem.
I log my car and my IAC is around 30 once it settles down. Once I give the car gas and let off my desired and my actual IAC goes to 0. When this happens the car will barely run. Sometimes I can restart the car and my IAC will open back up but most of time it doesnt.
I have already tested the IAC and it works fine.
My TPS stays at 2%. I can reset it and it will go to 0% but when I give it gas it will not rest at 0% again, back to 2%. My TPS voltage is .63 but I have adjusted it from .5 to .7 with no luck. I swapped in a new TPS and no luck.
My car will throw a TPS low voltage code sometimes. Also the last time I checked it had thrown a crankshaft position sensor code. This sensor I think could cause the car to idle like **** since it controls spark but Im thinking I could get this code because of the eratic signal its getting off the crank while the car is chugging trying to stay running. I hate to buy a 75 dollar part and that not be the problem.
Lastly my tach is about 500 rpm's off up top. I know this may point to the crank sensor but thing is when I had the 6 speed I shifted at 6800 on the tach all the time and with the auto I hit the rev limiter at 6500 on the tach now and rev limiter is at 7000.
I would love to hear reasons for the IAC falling to 0. The desired IAC goes to 0 also so the IAC motor is doing what its being told to do. I would also love to hear why the TPS stays at 2%. I have already verified that its returning to the stop on the TB.
Any help appreciated.
Old Oct 7, 2006 | 04:07 AM
ringram's Avatar
Maybe your tps connector wires have a short somewhere?
Why does your desired air go to zero? Which pcm table does this? (ie) If its RAF then fix that?
I had a guy I helped out he had issues with his tps, looks like it was the tps sensor, he is still working on it, but cracker would hold his rpm high with 16% tps, even though it was closed. Maybe the follower and cracker tables are coming into play due to the 2% tps issue.
I think you need to sort out the tps issue first, then worry about the rest of the stuff.
Old Oct 7, 2006 | 04:55 AM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
With that many different sensor problems, I would double check all of the ground wires before replacing parts. I just don't see the transmission screwing up your iac, tps, and crank sensor all at the same time.
Old Oct 7, 2006 | 05:52 PM
Full-Force's Avatar
I played with it today. I have never messed with the cracker tables. Only thing I have done is add some raf.
I found that if I reset the tps it goes to 0%. If I then scan the car the IAC is open around 30 steps. If I barely touch the gas so that my tps goes to 2% it will make the IAC go to 0.
I just got done tuning on another car this past week and noticed that when you give his car gas the IAC goes up.
What I did today was adjust the set screw on the tb to try and get my IAC counts up. That didnt help. The IAC flat out will drop to 0 if my tps is not at 0%. So what I did was adjust the screw so that I the blade open more and now the car idles nearly as good as stock but without any help from the IAC.
Im not getting a tps code or crank sensor code anymore
Old Oct 7, 2006 | 06:42 PM
ninobrn99's Avatar
it does sound like something with your grounds. too many things messing up at once. if you've checked the iac motor already, then check the wire for a short as mentioned earlier, check all grounds. make sure you didnt pinch anything with the swap.
