fast 90 install question (sticky TB)
Old Oct 8, 2006 | 02:48 PM
99WS7's Avatar
Default fast 90 install question (sticky TB)
Got the 90/90 on and she fired right up. Let it idle for a bit and all seemed good. Reved up in nuetral and did fine but when you go for a ride the throttle will stick between 2200ish to 3kish but a quick tap on the gas pedal to rev it up and it will drop back down to idle. Cleaned the mass air and TB very good and it still is doing it. Could I have a vac problem. Maybe not enough spring tension? Seems to have a good amount. Any ideas...
Old Oct 8, 2006 | 03:00 PM
oange ss's Avatar
sounds like a typical FAST t-body, throw it away and buy a Nick Williams t-body
Old Oct 8, 2006 | 03:03 PM
99WS7's Avatar
SOB....my buddie and I were just discussing that. What the hell is the big difference of the NW TB. I got a real good deal on my whole set up so Im not that pisses but damn. So no other thoughts. They make a good intake but a shitty TB.
Old Oct 8, 2006 | 03:06 PM
oange ss's Avatar
NW = work of art.......i have heard of people tryin to fix the FAST ones with no success, but i guess you could try
Old Oct 8, 2006 | 03:55 PM
99WS7's Avatar
we did the GSM (GAY SPRING MOD) got a spring going from the crusie contorl pin ummm....to the plastic next to the lid. Looks retarteded but it does work...lol. I'll get a pic later.
Old Oct 8, 2006 | 03:57 PM
ZL1Killa's Avatar
yep. get a nick williams. he is doing some more work too, so stick with him. might want to wait a while and see what he is releasing
Old Oct 8, 2006 | 04:38 PM
Phoenix 5.7's Avatar
i have a FAST 90 TB, and i will say it is a huge pile of ****. im gettin a holley or NW as soon as i can. im goin to try the spring mod for a temp fix, but its pathetic that its that crappy
Old Oct 8, 2006 | 04:44 PM
foff667's Avatar
LS1TECH Sponsor
i had some major issues trying to tune a car recently with a BBK TB....not only could you not set the set screw low enough, when you did set it to its lowest point the TB would stick & you'd need to give it 30% tp just to get it to unstick...horrible for around town driving.
Old Oct 8, 2006 | 07:12 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Even the ugly spring mod didn't help my fast 90. I gave up and went NW. I just wish the fast was heavier, so I could use it for a boat anchor.
Old Oct 8, 2006 | 11:45 PM
GreaseMonkey83's Avatar
sumbitch! so thats why my throttle hangs around 2100-2200 when i stop. i always thought it was in my tune.... i guess it is my TB. damn fast 90's. how are you guys doing the spring thing, any pics??
Old Oct 9, 2006 | 05:54 AM
TuneMaster's Avatar
Got the same problem here. Tuned a customer's vehicle and noticed the throttle body sticking at approx 2500 rpm. Had to fit a return spring from the bottom accelerator cable hole to the front stud for the pcv retainer. All better but going to swap for a Holley.
Old Oct 9, 2006 | 02:56 PM
99WS7's Avatar
for being so damn expensive thats bs that they are a pile of ****. I got a good deal on a lid, mass, tb and the intake but if I would have know about the fast 90 TB was such a pos I would have just got the NW to begin with. O-well you live and learn.
Old Oct 9, 2006 | 03:00 PM
monicaz28's Avatar
Yep, FAST tb's suck. I tried to tell my b/f not to get the FAST, go with the NW... but he was in too big of a hurry and did it anyways. The outcome was predictable.
Old Oct 16, 2006 | 04:49 PM
My90Iroc's Avatar
Contact Fast, I think they were/are offering replacement springs to help with this issue.
Old Oct 17, 2006 | 01:39 PM
gametech's Avatar
The spring is not the issue. The problem is excessive throttle shaft play, which will also leak vacuum/boost. A heavier spring just bandaids the pos.
