lt1 edit vs. Tunercat
Old Oct 13, 2006 | 12:34 AM
Ls1Bait's Avatar
I use LT1-EDIT and I think its great. I also Froze up my PCM (battery power was losted ) got a new PCM and my old editor didnt work so I emailed them and they said they would e-mail me out new software and got it in a day!!! There great to deal with.
Old Oct 15, 2006 | 04:25 PM
roughneck427's Avatar
Tunerpro is free you cant real time tune with the 94-95 PCM's no sense in paying the money for the RT version. http://tunerpro.markmansur.com/downloadApp.htm I myself use Tunercat but if your on a budjet Tunerpro is for free. www.mastach.com has cables for $40 ive personally used it and no problems. To use Tunerpro you will need the EE def file from Tunercat which is $20.I use TTSdatamaster for datalogging from what Tunerpro shows its a tuner and datalogger in one i dont know check it out. I know alot of other LT1 guys use it im just comfortable with what i have.
Old Oct 15, 2006 | 04:41 PM
Taubr Unit's Avatar
yea, im not opposed to pating for it and get a little more adjustements. This is IMO the most important thing when building a car. If your car isnt tuned right it wont run right. So i dont mind paying a few extra bucks to do what i want to do. But at the same time i dont got $2k to spend on a new computer.
Old Oct 21, 2006 | 07:05 PM
Kelly.'s Avatar
anyone know what the highest hp LT1 that is/was tuned on LT1edit?
what about Tunercat?
im debating which one to use.
ill be tuning a built 383 with a single front mount turbo.
thanks in advance
Old Apr 16, 2007 | 07:43 PM
Taubr Unit's Avatar
bump for a quicker find and anymore input?
Old Apr 17, 2007 | 04:59 AM
ModernMusclecar's Avatar
I use both in my car but Tunercats for all the fuel and timing tables. LT1edit makes changes in other tables than the value you are changing to make a tune that makes sense. For example, in an auto car, change the rear end gear ratio in Tunercats and thats all that changes, but when you make the same change in LT1edit the upshift, kickdown and a few other tables are automatically adjusted. There are many other changes that this automatically happens for aswell. I like Tunercats for its simple and quick tune building capability. I use datamaster to logs
Old Apr 17, 2007 | 09:30 AM
koolaid_kid's Avatar
Raised from the dead! Yes, for OBD1 cars, DataMaster will do the trick for data logging. My OBD2 car requires AutoTap for data logging.
LT1Edit turns out to be fairly flexible, but you have to wander about to find what you want to update. It includes a separate application for uploading/downloading the PCM.
Old Apr 17, 2007 | 10:07 AM
Taubr Unit's Avatar
well i got datamaster now to log and i love that program so far. So now i see everything wrong with my car. So from here i gotta fix some things and go from there.
