C0240, C0041 and C0036 Codes after cam
I'm throwing the following codes but the description close to useless. Any ideas on what can be causing these?
C0240: PCM Traction Control Not Allowed (ETS)
C0041: Right Front Wheel Speed Circuit Range Performance
C0036: Left Front Wheel Speed Circuit Range Performance
I would second checking the wiring on that. Mainly because I had an ABS Light on another vehicle and after replacing the hub I realized a connector was unplugged to that wheel speed sensor.
I have the C0240 code but that's the only one. HPTuners displays it like this
'Brake C0240 Immature History' I can NOT clear that code. Allegedly HPTuners can't clear BCM codes and so that code can only be cleared by a Tech2?
My Traction control will work then stop, then work, then stop. Loose harness?
If so, where should I look? Wheel sensor???? Is there a wiring harness or ground wire DIRECTLY related to the traction control PCM? Thanks!
I kno this is a old thread but I'm having these codes pop up after a heads, cam and stall swap I got a circle d 3600 stall and it seems like it doesn't wanna get out of first without me manually doin it from 1 to 2 I haven't gotten it tuned yet I just got the car back last night but I noticed it when I was babying it back home
