Speedometer correction ratio for Gear swap needed 98 F-Body
I know that to correct the speedometer in HP Tuners for 98 F-Bodies is a bit different than the 99+ since you have to do the whole Tire Diameter divided by Gear ratio. Then punch that number in the speedometer settings. The only thing is that I have looked at about 5 bins from stock 98 f-bodies and everyone has had a slightly different ratio from the factory (based on stock tire size/stock gear ratio). So it seems like from the factory there was really no set ratio.
I currently have 275-40-17's in back which roughly calculates to a 25.661 tire diameter and I have just a 12 bolt with 3.73's in the car. Should I just punch in 6.879 (25.661 divided by 3.73) on my Hp Tuners or is there a more exact correction factor to use.
Thanks.
Thanks.
Originally Posted by 2xLS1
GM uses 24.9x for the stock tire sizes on all year f-bodies so that's what I use. I use these values on 98s.
Gears Value
2.73 9.11
3.23 7.71
3.42 7.29
3.73 6.68
4.10 6.08
Gears Value
2.73 9.11
3.23 7.71
3.42 7.29
3.73 6.68
4.10 6.08
