02 Sensor Voltage Switching
Is this telling me that an 02 sensor is going bad or what?
Still runs great. NO codes yet. Stock motor right now.
https://ls1tech.com/forums/pcm-diagnostics-tuning/583508-i-called-bosch-tech-re-slow-oxygen-sensors.html
https://ls1tech.com/forums/showthread.php?t=583508
I read your thread..........damn what a saga that is! I hope you finally figure it out. I will follow your thread to see how it turns out.
Only difference is that I still have the stock manifolds and cats, etc. I have not installed the longtubes yet.....now I am a little worried after reading your thread!!!!
Thanks
Since your car is stock, I'd guess that you do have a bad o2 sensor. An easy way to trouble shoot your situation would be to swap the sensors from one side to the other. If the problem moves to the other bank, then you know you have a bad sensor.
Good luck.
Good luck.
Mark
I was going to switch the two to see what happens..but since I have a new bosch (yeah i know) sensor laying around, I might just toss that in bank 2 side and see what happens. If it fixes it...then I only had to change one sensor instead of swapping them around...then changing them.
Keep us posted on what you figure out!!!! I wont get a chance to mess with mine until wednesday or so.
Justin
Im going to toss the new O2 sensor in tomorrow and see what happens.
Justin
Justin
Let me know what happens when you switch sensors out. I am travelling out of town on business and wont be home until thursday night so I cant do anything right now anyway. My LT's and catted Y should be waiting on my doorstep when I get home!! I already bought the highly recommended Bosch 13111's for the LT install.
Im leaning towards the 13111s because the ACs are too expensive, and Ive heard enough success stories from the Bosch users to be convinced.
Justin
I installed the bosch O2 sensor into bank 2... Started it up...still sat at 450. Took it for a drive..parts of which were spirited. Still nothing. Pulled back up the driveway, was about to turn off the key when I looked down at the gauge. Both switching away. So I took it for another ride. No real noticeable difference in power. I think I need to get the car tuned mostly.
This morning when I got in her, they both started out at 450...and pretty much at the same time they started to switch. Slow at first...then faster and faster. Took only a minute or so before they were switching like normal. Once they start to switch, they mimic each other's behavior. Also the LTFT seemed to be closer to each other. Before they were way off from each other.
So I guess thats all that was. Now all I have to do is get two new ones from the Vette, and ditch the extensions.
Justin
Just curious...if they dont lock at WOT....what are some of the problems associated with this? My car seems to run great. No traction in 1st at anything above 1/2 throttle...but seems to lack it when banging up into second. I cant spin the tires into second. Its weird...
But anyway...Ill try to look at the O2 at WOT and Ill report back.
Justin
I cant think why they would actually lock at a certain number and stay there though.... They dont come back down to 100 or anything...but they dont exactly "max out" either.
I think Im going to get my throttle body, and try to go for a tune before crappy weather hits. Im sure someone with a good scan tool or HP Tuners will be able to tell better whats going on. As far as I can tell, everything sensor wise is working on the car. The MAF might still be messing with me..but thats going bye bye too before the tune.
MY02REDWS6TA: Let me know how you make out changing sensors when you get it done. Are you just going to plop the new sensor in? Or are you going to install all the other goodies you just got at the same time?
Justin
Justin
I just got back into town this evening so I havent messed with mine yet. My Bosch 13111's were delivered today. LT's and catted-Y should be arriving Friday as well. If I have a chance this weekend I may throw one of the 13111's in there to see what happens or I may just say the hell with it and just get the headers on and change them then. You did change out the Pre-cat sensor correct? Let me know. Even though mine isnt switching I have noticed no diminished performance.
MARK
Justin
