Speed Density Tuning
Old Oct 16, 2006 | 01:39 PM
MICAH HERRON's Avatar
From: Johnsonville, SC; but orginally from GAINESVILLE, FL
Default Speed Density Tuning
Can anyone enlighten me on this?
Plus, my MAP is at 57-58 and I am getting feedback that this can be an issue too.
My car is a 2000 A4 and I am running a 232/236 .575/.578 LSA 113 +2, and I heard that tuning A4 with lobe separation let this one can be a PITA.
Thanks,
Micah
Old Oct 16, 2006 | 02:05 PM
foff667's Avatar
LS1TECH Sponsor
http://www.hptuners.com/help/vcm_edi...dvanced_ve.htm
http://www.hptuners.com/help/vcm_edi...to_user_sd.htm
https://ls1tech.com/forums/pcm-diagnostics-tuning/284479-finally-how-tune-101-a.html
https://ls1tech.com/forums/pcm-diagnostics-tuning/149741-ve-table-cracked.html
https://ls1tech.com/forums/pcm-diagnostics-tuning/304025-guide-ve-tuning-using-fuel-trims.html
https://ls1tech.com/forums/showthrea...t=disadvantage
Old Oct 16, 2006 | 02:56 PM
Man, this stuff is interesting. I also have to be honest, some of it is going right over my head.
Old Oct 16, 2006 | 03:01 PM
foff667's Avatar
LS1TECH Sponsor
yeah its a lot to take in in one sitting or twenty lol
Old Oct 16, 2006 | 03:07 PM
I may just have to go to a tuning class.
To those of you that have a clue in tuning!
Old Oct 16, 2006 | 03:45 PM
TAQuickness's Avatar
Shouldn't be a problem. Check out the SD tuning link in my sig for an idea what's involved.
Old Oct 16, 2006 | 04:14 PM
brad8266's Avatar
Tuning is pretty simple once you understand how the PCM works and what tables do what. The actual tuning just takes a lot of time and trial and error.
Old Oct 18, 2006 | 10:58 PM
Dragman's Avatar
Not real bad once u get a handle on whats going on.
Old Oct 19, 2006 | 10:32 PM
spoolup's Avatar
Thanks,
Micah
Nope, not a problem. Try having 70-75kpa at idle. Based on your previous experiences, you might be able to do a better job. However, Learning on a stock car would be better. With your car, SD or SD/MAF will work well when tuned properly, either way.
spoolup
