idle question
Old Oct 16, 2006 | 08:37 PM
austin21's Avatar
Default idle question
if i lower my idle will that make it more obvious that i have a cam because right now it seems kinda muffeld ...thanks guys
Old Oct 16, 2006 | 08:46 PM
SSpdDmon's Avatar
Yes, but you may run into some issues if you set it too low. What kind of cam and where are you idling?
Old Oct 16, 2006 | 08:59 PM
austin21's Avatar
lg G5X2 and idel right now is 950
Old Oct 16, 2006 | 11:26 PM
SmokingWS6's Avatar
You could probably get away with 800 rpm. I tuned a G5x4 cam to idle at 900rpm.
If that is not enough you could take away a few degrees of timing at idle but that may open you up to more idle stability problems.
Old Oct 17, 2006 | 08:36 AM
SSpdDmon's Avatar
I'd say 850. Much lower and it may stumble occasionally and start to stall. The trick is to have the supporting tables set appropriately.
Old Oct 17, 2006 | 10:17 AM
austin21's Avatar
alright thanks guys
