BCM Replacement 2000 Yukon Xl - Does it need reprogramming?
I need to replace the BCM on my 2000 yukon xl.
I have found a replacement, also from a 2000 yukon xl.
Does anyone know if I need to have any programming done to the new BCM when i replace my old one???
Thanks in advance!!!
I would assume if the new BCM you got does not match your key, it will require reprogramming.
Good luck.
