0300 misfire after header install
Old Oct 29, 2006 | 10:52 PM
99FormulaWs6's Avatar
Default 0300 misfire after header install
I helped install a set of dynatech headers, Taylor 10mm thundervolts, and a new set of NGK TR55's on a stock 98 Camaro. The car is running like crap, and giving a 0300 misfire code. After the advice of my local tuner I checked to make sure all the wires were a tight connection, there were some that were loose. So we unplugged all of them and started all over, and it's still giving the error. Anything I could be over looking?
Old Oct 29, 2006 | 11:02 PM
2xLS1's Avatar
Real O2 extensions or cut and splice?
Old Oct 29, 2006 | 11:03 PM
10SecDreamer's Avatar
If an engine light is on I thought you had to go in with a scanner to clear the codes before the light would go off. Even after the problem was fixed??
Old Oct 29, 2006 | 11:22 PM
Real extensions, but that brings up another point, one of the 02's came unplugged and got wet...helpful hint #1: Always check your connections after an all nighter header install..Would that cause an 0300? I figured if that was it, it would have caused an error in the 02.
Old Oct 30, 2006 | 12:12 AM
Joel_SS's Avatar
More than likely.. Once when pulling the tranny I got a little oil on the O2 sensors and the engine ran like ****! It is amazing how shitty it will run if the O2 is not running up to par.
