Misfire and no codes wtf???
When the coverter locks it shutters like the engine is misfirin. Above 3500 it pops really loud like a bad mis.
I have no codes, all actual values look fine. This problem somtimes just clears up and it runs perfect.
Ive changed my plugs, wires, and frt o2s. Compression is right at 189 psi across the board. NO idea whats happening any ideas.
Check the Valve Srpings. Recently had a similar issue with valve springs if all else checks out.
