OEM crank trigger for aftermarket EFI
In anticipation of the Mega Squirt 2/Extra code being released relatively soon (well it will probably be released before I am ready to start my engine) I would like to know if anyone knows which two wires on the CKP sensor are required to get an equidistant 24x pulse signal out? Also has anyone scoped the output of the LS2 cam trigger? Based on pictures of the cam gear and the location of the sensor in the front cover, it looks like it is lined right up to trigger @ TDC # 1 (or slightly prior to it). The trigger "tooth" is exactly 180 degrees which equates to one complete cranskaft revolution. Also any idea what the third wire is for on the cam sensor? I was under the impression that you needed only two wires to generate a VR pulse.
Pages 30 and 32 contain a graphical display of the on and off pattern of the LS1 trigger wheel. It also has the wiring diagram of the sensors but unfortunately It is beyond me to decipher.Holden diagnostic Manual
Your welcome hint, sorry i forgot which edge though,
but i am glad i didn't have to measure a wheel. Yes the MS is a nice piece i remember efi332 if you want to go way back in DIY-EFI. The Best V8 Stories One Small Block at Time
