28-TCS codes are ON!
Old Nov 3, 2006 | 11:21 PM
Blown04Z06's Avatar
Default 28-TCS codes are ON!
can anyone tell me what these mean or stand for or what needs to be replaced?
28-TCS
C1278
C1282
C1283
C1284
C1285
C1287
C1288
C1296
'04 Z06 with a LS2 403 swapped in, brake lines were completely drained because the abs system was dropped out with the whole front craddle. I didnt do the work someone else did, but these didnt come on until 2 weeks after the install.
any help would be greatful
thanks in advance
Old Nov 4, 2006 | 12:17 AM
Blown04Z06's Avatar
ok after being directed here....http://www.corvettedoctor.com/2004_DTC_Codes_Page2.html
here is what i have decoded..... any help would be great
DTC *C1278 TCS Temporarily Inhibited By PCM
DTC C1281, *C1283, or C1286 VSES Sensors Uncorrected
DTC C1282 Yaw Rate Sensor Bias Circuit Malfunction
DTC *C1284 or *C1285 Lateral Accelerometer Circuit
DTC *C1287 or *C1288 Steering Position Sensor Circuit
DTC C1292, C1293, or *C1296 Master Cylinder Pressure Sensor Circuit
*marks the code that is throwing
could there be some wiring unplugged somewhere? or not being connected properly? i have no idea where to look.
Old Nov 10, 2006 | 06:29 PM
Blown04Z06's Avatar
ok well i realign the steering shaft. cleaned all of the grounds and the 2 connectors on the ebcm, cleaned the connector on the master cyl and 2 days after the fact. all of the codes turned off. freaking crazy!
