Cheaper wideband setup?
Old Nov 5, 2006 | 12:25 AM
pHEnomIC's Avatar
Default Cheaper wideband setup?
Ok I was reading on how to wire an oxygen sensor into hptuners without EIO. Would that work if i just got a cheaper bosch wideband and spliced it into a pcm sensor input?
In particular something like this:
Five wire BOSCH Lambda Uego ( LSU 4.2 )
I believe it is compatible with the lm-1 or lc-1 btw.
Basically, if I wire the wideband into a pcm sensor input, can i work the thing without getting an lm-1 or lc-1 control unit?
Old Nov 8, 2006 | 09:07 PM
WS6 GreeN's Avatar
I'm pretty sure you can't, or everyone would be doing it. The wideband sensor is way more complicated than the narrowband and has to have electronics to interpret the signal and control it. Our narrowbands are 0-1volt where the wideband reads 0-5v. You CAN wire the LC-1 into HPTuners without having the EIO, through one of the AC sensors.
Nice car btw!
Old Nov 8, 2006 | 09:22 PM
foff667's Avatar
LS1TECH Sponsor
you still need a controller no matter how you look at it.
Old Nov 8, 2006 | 10:19 PM
pHEnomIC's Avatar
Alright so i decided.
Hp tuners standard edition
and this:
http://www.dynotunenitrous.com/store...?idproduct=151
I already have a compatible autometer gauge. I will run the other input through my egr or something and read it through the pcm.
700$, can't get much cheaper than that.
Old Nov 12, 2006 | 12:03 AM
Shallow Bay's Avatar
Here's a way better deal for only $29 more.
http://www.greenlightmotorsports.com...products_id=39
Old Nov 12, 2006 | 12:38 AM
Doc's Avatar
Doc
Dude,
You might as well be trying to sell a bible to Saddam Hussein
Old Nov 12, 2006 | 05:32 AM
Black02SS's Avatar
$699 for that link if you change your mind and free shipping.
Old Nov 12, 2006 | 04:49 PM
pHEnomIC's Avatar
Originally Posted by Doc
Dude,
hahaha.... i will check it out tho
Old Nov 12, 2006 | 05:17 PM
Doc's Avatar
Doc
Take the blue pill
