MAP sensor/electrical help please
circuit externally produces a full-scale MAP
voltage (and can be detected as a fault, as
MAP normal range is 0.5 - 4.5 or so).
2.1V might be a sane atmospheric voltage for
a 2-bar MAP, or a fairly normal idle MAP at
40-50kPa or so for a 1-bar.
Don't know about the 9V other than that it's
well outside the MAP sensor expected supply
range and maybe the internal electronics are
bent by it.
That should stay at 5V.
If the voltage is pulled down by both sensors, then the PCM may be bad...
(...I said "may"...)
It was applied as a test for 3 seconds to see what would happen. The MAP is fine. The 8.89v reference came from an un-used pin on the red PCM connector. The PCM is a much bigger problem. Thanks for the post though. I do appreciate all replies.
From all you say is going on, something sounds amiss. If I had some extra time I'd go check what mine reads. I think that is what you need to hear.....what is normal.
Keep in mind that the 9v MAP test was done yesterday, long after the other issiues had damaged the PCM. I also have more than one MAP sensor that can be used should there be a problem. There is no 5v reference from the original pin location for the MAP. That circuit inside the PCM is gone. An alternated 5v reference is being used.
I think that the issue has been found & it is as described by joecar & jimmyblue. We know for a fact that the PCM curcuit used to control the EGR, MAP, & A/C pressure is damaged. This most likely effects all of the 5v reference curcuits within the PCM because all of them result in the dropped MAP voltage when the MAP sensor ground wire is connected & not all of them work (for example the MAP sensore feed). Likely, within the PCM there is a short to ground. Even when the TPS 5v volt reference was used as a reference MAP source, it too dropped & effected the TPS as well.
The PCM is damaged. I have not yet tried to run w/ the alternate 5v reference from pin 71 on the blue conector without grounding the MAP sensor.
This would be the pull up circuit mentioned by jimmyblue & is the one method used where the 5v reference to the MAP & the signal from the MAP work properly (5v ref & feed back connected w/ no ground). I believe that connecting the MAP this way will work. Who knows for how long. When this method eventually fails, the PCM will be replaced. Good news is that when it is replaced, the issue that damaged the first two PCM's will have been corrected.
A normal MAP sensor w/ MAP sensor in place & wired has a 5v reference, feedback somewhere in the 4 volt range depending on elevation, & a ground.
