help car smokes white and has a code of C0056
Old Nov 8, 2006 | 03:42 PM
sick01ws6transam's Avatar
Default help car smokes white and has a code of C0056
I have a 01 ws6 trans am m6. it has victor jr. lt and gm hot cam alum fly wheel and dts rockwell 12bolt. The car stared smoking about 3000 miles after cam install. it has a few header leaks but nothing major. The smoke is white with a little blue. on cold cranks it blows out blue, but then clears up after a couple of min.
Old Nov 8, 2006 | 08:42 PM
blownbird355's Avatar
the blue at start sounds like valve seals
Old Nov 13, 2006 | 12:41 PM
The car is not putting out any codes other then the ABS, but the car smokes only white on the top end. Does anybody else think is a fuel problem.
Old Nov 13, 2006 | 12:43 PM
could the valves have not sealed when the cam was put in.
Old Nov 13, 2006 | 01:50 PM
brad8266's Avatar
White smoke is coolant. Check head gasket.
Old Nov 13, 2006 | 01:51 PM
brad8266's Avatar
Fuel causes black smoke.
Old Nov 13, 2006 | 01:52 PM
brad8266's Avatar
You didnt mess with the valves when you swapped the cam did you?
Old Nov 13, 2006 | 02:22 PM
i put in new valve springs, but use a compression tool that srewed into the spark plug hole to hold the valves up.
Old Nov 13, 2006 | 03:00 PM
brad8266's Avatar
Ah i see, the seals are probably messed up then if youre blowing oil into the chamber.
Old Nov 13, 2006 | 10:32 PM
so a new set of heads should fix my problem?
Old Nov 13, 2006 | 10:34 PM
or is their any thing else that i can do
Old Nov 14, 2006 | 05:48 AM
mathef's Avatar
White Smoke=coolant
Blue Smoke= oil
black smoke = fuel
