Cant view my timing table
First off your turbo yet they did a 1 bar SD tune utilizing the stock OS...thats problem #1, because when you do that you automatically drop to the low octane table which yes is commanding 10*
also doing a 1 bar SD tune with a turbo really doesnt work well period...the VE table is set to like 180% in those cells & overall fueling will probably be shitty at best.
So they said they should do a two bar tune but they could make something work for the mean time. I was told there would be a dip in acceleration from when the map hit 0psi with no vacuum. Other than that the car runs great. I never run lean, but I was hoping to put a few more HP to the wheels/. I had a few other issues with the car that we found during the dyno sesion, like the intake elbow blowing off and the IAT sensor blowing out at 6.5 psi.
And a fuel pressure drop, and now these are all fixed. So your thinking with a proper SD 2 bar tune I should be able to get the numbers I'm looking for? Sorry for my bad typing had a few to many beers tonight
