Pe Enable Tps,, Hot Select 284f
Old Nov 18, 2006 | 11:51 PM
zrater's Avatar
Default Pe Enable Tps,, Hot Select 284f
Do I Have To Set This Under 195 To Get Totally In To The Pe
Tables, Its In O/l..
Old Nov 19, 2006 | 09:22 AM
muncie21's Avatar
It's not necessary to enable the 'Hot' setting. You can if you want though.
Old Nov 19, 2006 | 10:44 AM
jimmyblue's Avatar
Moderator
There are two PE tables and below this temp
you are using the "cold" one. "Hot" would be
for a cooling fault protection kind of enrichment.
