2bar or 3bar tune
Old Dec 10, 2006 | 10:02 PM
2002ws-6's Avatar
Default 2bar or 3bar tune
Getting my car dynotuned with the small 2.5 bar MAP sensor (12580698) using HP tuners. Do I get a two bar tune, or three bar tune on a 2002 f-body? I have searched, and I have checked out hp tuners site, I can't find a definitive answer.
Old Dec 11, 2006 | 08:08 AM
foff667's Avatar
LS1TECH Sponsor
I assume you could do either, its just the map that holds you back. If you applied a 3 bar custom OS the map would only read to 2.5 bars. Personally though I would just do the 3 bar & be done with that. Should be the identical resolution so theres no real drawbacks with doing a 3 bar rather then a 2 bar.
Old Dec 11, 2006 | 09:05 AM
Slowhawk's Avatar
LS1Tech Sponsor
If your running under 15lbs of boost just do a 2 bar tune.
Old Dec 11, 2006 | 09:17 AM
foff667's Avatar
LS1TECH Sponsor
any reason why? I would always leave room to grow in the future as long as your not loosing any resolution.
Old Dec 11, 2006 | 11:58 AM
smokinHawk's Avatar
unless your like me where your pcm doesnt have enough ram to support 3 bar and RTT
Old Dec 11, 2006 | 08:11 PM
2002ws-6's Avatar
Well my question is and tell me if im backward or not. Lets say for example the stock map reads 0.0volts for 29" vacuum and 5.0volt for 0" vacuum. Wouldn't the two bar sensor show 0.0 for 29" and 2.5 volts for 0" and 5volts for14.7psi. The 2.5 bar would read 0.0 for 29" and 5.0 at 22psi wouldn't the 0" be off?
