SS is a dog
Old Dec 17, 2006 | 01:35 PM
SSTowerman's Avatar
Default SS is a dog
down low. Seems like I can't get the rpms up fast enough. Is this a tuning issue? How much will gears and a pulley help? The throttle response down low is just *** slow and it makes me angry. I see the mustangs just flick a rev and I'm jealous. Any suggestions?
Old Dec 17, 2006 | 01:39 PM
M6HuggerSS's Avatar
more important....
-what mods are on the car now?
-any dyno numbers?
-how many miles on the car?
-is it well maintained?
Old Dec 17, 2006 | 05:28 PM
SSTowerman's Avatar
Lid
Catback
EGR mod
FRA mod
very well maintained at 76k
always 93 octane
Royal Purple
no dyno #s
Old Dec 17, 2006 | 07:30 PM
foff667's Avatar
LS1TECH Sponsor
has it ever been to the track or is this just a sotp feeling?
Old Dec 17, 2006 | 10:06 PM
SSTowerman's Avatar
Never been to the track. I dunno what sotp means. I just think that it should rev up quicker than it does since it's a small block . The motor feels slow and lethargic getting up the rpms.
Old Dec 17, 2006 | 10:13 PM
Sean Collins's Avatar
The know it all's know it all
ls1 power curve really doesn;t wak up on a stock engine till around 3500rpm or so. soft or just doens;t pull as hard ?
Old Dec 17, 2006 | 10:23 PM
SSTowerman's Avatar
I understand where the powerband is. However, I feel the motor should make rpms quicker. Am I mistaken?
Old Dec 17, 2006 | 10:35 PM
erikthegoalie's Avatar
sotp=seat of the pants
Old Dec 18, 2006 | 07:54 AM
SSpdDmon's Avatar
So, you're wondering why the rpms don't come up quickly on a nearly stock car? The lid/catback is a good step in the right direction for bolt-ons. The '99 M6 I had didn't do half bad with just those mods. But, the best I could run at the track was 105mph in 13.4 seconds on a 2.0 second 60-foot.
In my opinion (and don't take any offense to this because we're not all John Force), it's driver error assuming all is mechanically sound. If the rpms aren't coming up fast enough, you're either in the wrong gear or your bogging it off of the line. Even near-stock LS1's shouldn't feel like you're waiting for v-tech to kick in. If you're used to driving an LT1, it is a little different having your torque curve shifted up a quite a few rpms. But, you still haven't lost any ft/lbs. If anything, you've gained a few.
Just curious, but why is this in the PCM section??
Old Dec 18, 2006 | 09:09 AM
foff667's Avatar
LS1TECH Sponsor
because apparently he thinks its a tuning issue
Old Dec 18, 2006 | 09:15 AM
SSpdDmon's Avatar
Well, I'd say no way with only a lid/catback. He might be running slightly rich with the factory tune...but, that's about it.
Old Dec 18, 2006 | 09:50 AM
pdanrichey's Avatar
My 99 SS vert kicks A$$ with just a lid, filter, and ported TB. With the tune on, it's even more so pimp. Seriously, mine just gets up and goes...scares the wife sometimes.
Maybe you're losing power to the tires...rear-end making any noise?
Damn, even in 2nd gear at 10 mph, I'm upto 60 in like 6 seconds, + or - of course.
Old Dec 18, 2006 | 10:15 AM
sapper_daddy's Avatar
I would just suggest bringing that thing to a dyno and posting up the chart for comparision to other stock dynos and you'll see if it is lugging for some reason. lots of info you can use there and doesn't cost a whole lot i think to just pull down numbers. It is definitely a motor that likes to turn RPMS to make torque!
Old Dec 18, 2006 | 06:28 PM
M6HuggerSS's Avatar
revs slow compared to what? a 4cyl.?
how long have you been driving this car? and what was your last car?
im still unsure if you mean that it is revving slow all of a sudden or you just got the car and these are your first impressions.....
and being a small block has nothing to do with how it revs..... you are throwing around 8 cylinders... not 4.
i have a fealing that you are bogging the gears.....
more info needed.
Old Dec 19, 2006 | 01:52 PM
pdanrichey's Avatar
I have a simple theory. Check to see if the TB cable is hooked up right. It's possible that there is slack in the line and when you floor it, you're not actually "flooring it." Try figuring out if it's something simple like that before you start messing with other items.
Old Dec 19, 2006 | 02:34 PM
SSTowerman's Avatar
more info needed.
It's my second SS. I know what to expect. With the car in Neutral, press the gas a little and it seems that the tacometer doesn't jump like it should. It just builds rpms too slow imo. Throttle repsonse is slow, and making rpms is slow imo. I know how to drive the damn thing. I don't gear bog it. I just wonder if the motor can respond better to a quick pedal push in neutral. Or when rev matching to down shift. That seems to take longer than it should too. I thought this might be a tuning issue.
Old Dec 19, 2006 | 03:32 PM
he is right, I had the throttle cable bracket on my f150 back out because it was supposed to be thread locked, when it got some play after backing out some, it felt like I was pushing the throttle to the floor, and I was but the whole bracket was moving! So check the simple stuff first, and I hope it is something simple and cheap to fix for you!
Old Dec 19, 2006 | 04:12 PM
SShawn's Avatar
could also be your TPS. maybe a plugged fuel filter, any codes?
Old Dec 20, 2006 | 01:36 AM
SSTowerman's Avatar
Ok, I'll be checking some more simple stuff then.
