turbo tuning
I have hp tuners software and an aem wideband. Im pretty familiar with how things work. I have been tuning for around a year. I tuned for nitrous and the mods I hav without any problems.
I plan to run 5-8 or maybe 10 psi if I can get away with it without a SD tune. I will be upgrading to 2 bar as soon as I can get the extra money. But for now its lower psi and the maf.
I looked at the predator safe 5psi tune that come with it and its pretty much the same except lower timing and lower afr.
I know I need to keep my a/f around 11.5-12.0. I need to pull timing as well. How much timing for 5psi and for 8 psi?
I assume under part throttle everything should stay around the same correct? I already have the tables for the 42lb injectors as well.
I guess my basic questions are..
What timing?
What esle besided timing, a/f ratio, injector size, needs to be tuned? I assume the ve table may also need some work since it will hit boost sometimes at part throttle..
Are there any close places to memphis other than futral that does good tunes? Is Gomer still doing any tuning?
If anyone has a turbo tune they can send me to help me get started that would be great.
Tiger2o69@hotmail.com
