Knock sensor...unplugging same as disabling in PCM?
Old Dec 21, 2006 | 10:52 AM
Stroker2112's Avatar
Default Knock sensor...unplugging same as disabling in PCM?
Guys,
Would physically unplugging the knock sensor harness provide the same affect as disabling them through/via the PCM ?....In other words, how would the PCM respond (throw more DTCs?) by unplugging vs disabling?
Stroker2112
Old Dec 21, 2006 | 02:39 PM
Guess not since no one is responding....I'll leave them plugged in.
Old Dec 21, 2006 | 03:34 PM
thunder550's Avatar
High on diesel fumes
Unplugging them will set the DTC and put you into either the low-octane table or something, I can't remember what exactly, but it pulls *** loads of timing.
Old Dec 21, 2006 | 10:32 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
On my GTO, if a knock sensor isn't plugged in it automatically reads 2.9* knock retard.
Old Dec 21, 2006 | 11:42 PM
5.7 ute's Avatar
As thunder says. It will default to the low octane table.
Old Dec 22, 2006 | 10:06 AM
Got it, thanks....I'll leave them be.
