EFILive
Old Jan 7, 2007 | 04:52 PM
STKN1STGEAR's Avatar
I think this is the command fuel when in open loop B3605?
Al
Old Jan 7, 2007 | 05:34 PM
ringram's Avatar
If you are in open loop speed density then you need to first check what your commanded fuel says. If it doesnt match what you are seeing on your wideband etc, then you need to adjust your VE table to get them in line. Thats the whole point of the autove tuning and the basic start point of a baseline tune.
Old Jan 7, 2007 | 05:38 PM
Doc's Avatar
Doc
First things first. You do have a Manifold Air Pressure Sensor (MAP) installed in the manifold correct? This is a 408 right? Bigger motor than the 346 so you will need to adjust B0104 to the correct cylinder vol to start. Do you have aftermarket fuel injectors, fuel system as well? If so, goto the stickies section and download Marcin's Fuel Injector Flow spreadsheet and get an accurate reading of what your test port on the fuel rail reads and plug all of that info into the spreadsheet. Rescale B4001 accordingly. Now employ the AutoVE proceedure as per the tutorial and you will be on your way to bliss.
Very important to let the OS know (by the aforementioned adjustments) that you have a 408, and fuel system mods, and not a stock 346 or you will be going on a very frustrating adventure based on fudging tables that in the end will never be right.
Old Jan 7, 2007 | 08:00 PM
Thanks for the reply
Yes I have a MAP sensor installed. This is a 6.0 liter motor, I did change B0104 from 708.2 to 750.0. I think this is correct. 6.0/8 = .75 liter changed to CC = 750 cc/cyl. yes I have after market 60# injectors @ 65PSI of fuel at the rail.
I didn't see "Marcin's Fuel Injector Flow spreadsheet" in the sticky. do you have a link to it?
Thanks
Al
Old Jan 8, 2007 | 10:41 AM
tunedportcj5's Avatar
I've got an LS2 in my '98. The PCM was swapped to a '99+ and I'm running the 2002 12212156 OS.
Here is the link to rescale your injectors. (Excel Spreadsheet) http://www.allmod.net/hpt/injectors.xls
Good luck!
Old Jan 8, 2007 | 10:49 PM
Good luck!
Thanks for the info.
What are the specs on your setup?
LS2:
Heads:
Cam:
intake:
exhaust:
Injectors:
Fuel Pressure:
Super charger:
ECT????????????
How does it run?
Did you have it dyno tuned?
If so, what are the numbers?
I'm trying to get to 550 RWHP.
I should be able to get it.
I'm taking it to get dyno tuned on 1/20/07.
Just for the base tune. still have to break in the motor before I get it tuned for proformance.
thanks
Al
Old Jan 9, 2007 | 09:14 PM
'05 LS2 long block, stock 243 heads, 240/244 cam, Comp 918s, FAST 90/90, SVO 42s
No ECT with the FAST setup
I'm running a '99 PCM with a custom 2002 OS, '99 engine harness...
No dyno tune yet - just lots of street tuning.
It will be at the track this weekend, I'll post up the results!
Old Jan 10, 2007 | 10:46 AM
WOW!!!!
Sounds Like fun. What track do you go to?
So you are NOT running a supercharger?
I'm looking for a tun with a supercharger close to my setup for ref.
Good luck
Al
Old Jan 10, 2007 | 12:00 PM
We usually go to Gainesville Speedway, only about an hour away.
One day I'll have FI
Old Jan 10, 2007 | 01:14 PM
Great !!!!!
The closest track here is about 2 1/2 hrs.
We get up there a couple times per year.
Great fun
