Tranny shift kit by PCM
I bumped the max line pressure up from 90 to 120.
I took the "Torque Step size 4 table lookup" to 1500
I took the "max allowable torque" up to 1280ft lbs
I found several torque management tables and disabled them or maxed them out to keep them from pulling timing,
And I took the "negative and positive force motor current" tables and multiplied them by .5,
I took the "time for shift" (somthing like that) and dropped it to .200 on all cells,
I took the line pressure for shifts normal mode and matched it to the performance mode which was 90psi across all cells,
And daymn what a difference! This tranny shifts just as hard as my old 4l60e in my truck which had the "race" kit from trans-go in it!
I haven't put in my pressure gauge into the line port on my transmission of verify the tranny pressures, but I can tell you this, burning second gear is nothing! Now my G/F doesn't like the shift cause this setup right here, it shifts hard! I love it.
Now for those of you who play with the tranny tables, have yall ever done anything like this?
Feedback welcome.
Thanks
D Moss
ONE is, if you set the max line pressure up from 90 to 120. That is bad, The Force motor current table does not go that high so after 96 it will try to mess up on amps to the pressure control solonoid.
Two is, That you should never run MAX line pressure like you are when you set the table to 90. It is now using the lowest amp you commanded on that force motor current table.
Three is, When you are using a shift kit, it is unwise to mess with pressures. If your trans is not shifting hard/fast with one, then you probably did something wrong on the install.
On the force motor current table, the lower the value, the higher the pressure.
This thread is 6 months old, dead, and my transmission is shifting hard and fine!
Have you tried it? Did it tear your transmission up? Do you have any proof that it will tear one up, cause if you don't, then you're blowing smoke up the wrong persons a$$, cause my tranny is shifting fine, hard, and I've been smoking peoples *** with this same car/tranny that everyone has been bashing me on.....I've raced WS6's, SS's, z28's, and everytime I shift, you can see me walking away from those poor slow shifting cars.....just keep your slow shifts, and I'll keep mine.
Proof, not myths, not theroies, proof.
But it's your ****... you were warned by several people in this thread already that know quite a bit about it and whadda ya do, crap on what they tell you. I just hope that people that read this section looking for info don't do what you are doing.
And if something does happen, I'll tear the tranny apart, take picks, and post up what happened, and go from there to repair it. Just so yall can say, "look I told ya so", but lets see how long it takes. I've rebuilt several 4l60e's, put shift kits in several, so it won't be a problem if it does fly to pieces, it won't be the first one to go, and I'm sure their pressures wasn't the problem.
high line pressure + time = disaster...
Dmoss69 settings + time = don't do
lol... the more I re-read the funnier it is...
