HP Tuners has added a few more demo's..
LS1TECH Sponsor
Originally Posted by Phoenix 5.7
so i will have to upgrade to MPIV to use autotune? and will it need a WB to fully take advantage of the capabilities?
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Originally Posted by foff667
correct, 98's are um "special" to say the least ![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
Basically we are the the only ones that even offer a 2 bar custom OS for them, but with the extended VE table & the other tables we add it doesnt leave us enough room in the excess ram to allow enough functionality of RTT unfortunatly![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
LS1TECH Sponsor
Originally Posted by JimMueller
Ahhh, so if the extra tables could be removed... ![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
LS1TECH Sponsor
the Auto VE your thinking of is just the histogram copy & paste feature which hptuners has had since inception basically, EFILive just coined the term with a fancy name. What we are referring to is our Real time tuning solution adjusting your VE, spark, maf, pe tables by themselves AS YOU DRIVE without you punching a button ![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Kleeborp the Moderator™
#34
LS1TECH Sponsor
LOL, you guys are great. ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
True Auto-Tune should be great for us all.![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
In the mean time, don't forget that you guys can copy the histogram and paste special direct into your RTT window.. RIGHT NOW!!!![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Just do it when your pulled over, not while driving, LOL!!!
#36
Originally Posted by MeentSS02
That's all fine and dandy, but will it feed me as I drive? THAT would be a true innovation. Then I could be the lazy, fat glutton that I've always known I could be. ![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
#37
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Do I need a wideband option to use RTT ? I know it would be ideal, but it's not required is it ?
So, RTT is in a way "autotune", with an exception that I actualy need to copy the "corrected" values into new table and write the calibration, whereas "autotune" does it automaticaly, correct ?
#38
LS1TECH Sponsor
ideal for tuning fueling yes, needed though...no not needed, RTT is just a simple custom operating system application which takes about 5 minutes start to finish to apply.
As far as "autotune" goes it will basically apply the changes for you while your driving, making the corrections as you go rather then having to use the copy-paste feature
#39
LS1TECH Sponsor
Here's a demo showing truely how quick & easily you can setup Real Time Tuning or ANY of our custom operating systems for that matter ![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
http://www.thetuningdoctor.com/HPTun...pplication.swf
