pcm system help
Old Jan 9, 2007 | 12:29 PM
bumpin_records's Avatar
Default pcm system help
OK bare with me while i try to word this right. I have a 96 v6 firebird. im putting a ls1 370 in it with a 91.5 turbo. Now seeing i have no ls1 harness im looking to go with bs3 system but i wanna keep my stock guages like tach and mph oil and so on. I heard you would have to keep your stock harness if you wanna keep your stock guages. would i have to still run a stock ls1 harness like a 2000 harness and pcm to keep those guages working. Im also switching to a 2000 dash cluster. Also if i use the 2000 wire harness and pcm instead of what else will i have to use to run big injectors like 96lbs and up. I have seen guys run some very very fast numbers "8's" with the stock pcm but since i dont have non of that will it be better just to buy a complete bs3 system? I hope i exsplained my self good enough. thanks for the imput guys
Old Jan 10, 2007 | 04:25 PM
can anyone help me
