slight KR problem
Old Jan 10, 2007 | 07:27 PM
DaddySS's Avatar
Default slight KR problem
I am running AFR 205s milled .018 for a 63cc chamber and an XER 220 224 114 +4 on stock bottom end.
SCR 11:1 and DCR 8.9:1 with a .034 quench on 93 Octane
With this combo I am getting very slight KR at about 4300 but mainly when I let off the throttle or let off and reapply.
Thoughts?
Brad mentioned Transient air but I can't find it in EFI live.
Old Jan 11, 2007 | 10:12 PM
ChrisS@sdpc's Avatar
Out of curiosity, did you tune your VE table? Are the values in the that area of the table 'somewhat' different than the surrounding areas on the table? I would also look at your spark tables in those areas as well. Assuming you have DFCO enabled, you could try disabling it to see if that makes a difference. Fueling during transition is somewhat more complicated as the process of metering the air is less accurate. That is when it can become more important for a proper VE table as it is given more weight for fueling calculations. Just some food for thought. Do you have a scan?
