For tuning, need tech specs on SVO 42lb injectors to set into HP Tuners
1 Post
Checking my tune. Need the following info. Search was unable to help:
static flow:
impedence:
gain:
offset:
turn-on time:
turn-off time:
Anyone that has this info or can point me to it.....much appreciated
static flow:
impedence:
gain:
offset:
turn-on time:
turn-off time:
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
There are many that have setup those injectors with success. I am not for sure you will find the specific pieces of information that you are looking for, but I believe you can find what you need to get them to function well with a stock PCM. You might here as he has done a lot of write/work regarding injector flow.
