P0300- Misfire code
Old Jan 14, 2007 | 07:23 PM
DustinWS6's Avatar
Default P0300- Misfire code
Yea, my car is throwing that code
Had it tuned back at the end of July 06 after swapping in a cam. Is the best idea to just call the guy who tuned my car? I read that many things can contribute to a cylinder misfire.
Also, is it okay to drive the car?
Old Jan 14, 2007 | 07:27 PM
ls1muscle's Avatar
Have the tuner turn it off, and no I don't mean clear the SES light. If he doesn't know what your talking about, find a new tuner. I drove my car for 2 weeks with that code being thrown with no problems.
Old Jan 14, 2007 | 07:45 PM
2001NBMZ28's Avatar
My car has thrown P0300 a couple times over the years, I just reset it - why not try just clearing the code first and see if it comes back?
Old Jan 14, 2007 | 08:40 PM
ChrisS@sdpc's Avatar
Do you know if the tuner modified any of the knock settings? Yes, I would contact the tuner. Many tuners will update the tune at no charge particularly when there have been no other modifications. That 111LSA could definitely trip the sensors at idle or low RPM. You should double check the plugs and wires just for peace of mind.
Old Jan 14, 2007 | 08:46 PM
DustinWS6's Avatar
Yea, I have cleared it two times and it has came back
Old Jan 14, 2007 | 08:48 PM
Rhino79's Avatar
Every cammed motor I have tuned has had the same issue, and the automatic guys converter won't lock up. I usually increase the values in the misfire tables.
Old Jan 14, 2007 | 08:51 PM
DustinWS6's Avatar
I dunno, I have tried to PM him but his box is full. I guess I will try his number tomorrow if I can find where I put it. I'm thinking about checking the plugs and I need to do wires since I have never done them
What bothers me is that it has just now started doing it. Never got it the first few months
Old Jan 14, 2007 | 09:05 PM
2001NBMZ28's Avatar
Just started after several months - doesn't sound like the tune...
Old Jan 14, 2007 | 10:13 PM
Doc99SS's Avatar
I had the P0300 mis-fire code a bit more than one year ago. After doing alot of coil swaps, spark plug swaps, and more, it turned out to be a broken valve spring. Very strange, it was not what anyone would typically expect. I changed the valve spring and clear the code. The code has never come back.
Old Jan 15, 2007 | 07:06 PM
DustinWS6's Avatar
I hope not. I need to do plugs and wires anyways
Old Jan 15, 2007 | 07:30 PM
hnaskoct's Avatar
my car is throwing that code also anyone have some suggestions i have new wires and plugs and my coils are sparking good..
Old Jan 17, 2007 | 01:21 PM
DustinWS6's Avatar
Ugh! I cleared it and it came back this morning. Car idles and run fine though. Could my loose exhaust clamp causing my duals to rattle cause it to throw the code?
Old Jan 17, 2007 | 01:28 PM
foff667's Avatar
LS1TECH Sponsor
yeah, larger cams seem to set off a red flag & give you the ole p0300 code...best to just disable it in that case.
Old Jan 17, 2007 | 01:34 PM
People have definitely had issues with stuff 'banging' around and causing false misfire codes. Not for sure about a rear exhaust clamp doing this (assuming you're talking about something back around the catback). More likely that 111LSA.
Old Jan 17, 2007 | 02:54 PM
DustinWS6's Avatar
Well, I have duals that are dumped before the axle and it's definitely banging back there. I thinking It happened when I scraped my mufflers coming out of a parking lot.
So you think it's because of my 111LSA cam? It does shake pretty good
