How quick do i need a tune?
Old Jan 21, 2007 | 03:18 PM
sidewayz28's Avatar
Default How quick do i need a tune?
ill first start off by saying in august of 06' i installed a 232/234 .595/.598 112 cam and got it dyno tuned later that month... fast foward 6 months. over xmas break i installed a set of untouched 243 heads, and a 90/90 set up.. the only real problem im having right now is surging when it first gets started up..i usually give it a little gas to help find its idle, but after a few minutes itll stay around ~900-1000rpms.. the car runs stronger then ever though. i think im going to pull a plug to see how it looks, but i was hoping i could get by driving it like this until i get my nitrous hooked up and then ill get it re-tuned around may. will it be ok to drive it like this?
Old Jan 21, 2007 | 03:48 PM
Bill Bowling's Avatar
You really could use a WideBand to determine where you are. Do you have any logging/tuning software?
Bill
Old Jan 21, 2007 | 03:57 PM
sidewayz28's Avatar
i do not i should add this is my DD and ive put about 500 miles on it
Old Jan 21, 2007 | 09:00 PM
koolaid_kid's Avatar
You might also consider purchasing scanning/tuning software of your own, or use a friends.
IIRC, a wideband is for WOT.
Old Jan 21, 2007 | 09:42 PM
fastz28ls2's Avatar
Yeah you need to get your a/f ratio checked and get a tune from a professional.
Old Jan 21, 2007 | 10:29 PM
sidewayz28's Avatar
i know that... thats how i got my car tuned when i had my cam installed... i had dyno tuning done.. my question is will it be ok to drive my car until like may?
Old Jan 22, 2007 | 07:13 AM
slow trap's Avatar
i don't see why not. other than the surging the computer should be able to keep your a/f at part throttle very close. i would try and avoid w.o.t since you may or may not be running alittle leaner now.
Old Jan 22, 2007 | 02:44 PM
sidewayz28's Avatar
thanks for the advice! appreciate it
Old Jan 23, 2007 | 08:15 AM
yobabiesdaddy2001's Avatar
I dont see why not
Old Jan 27, 2007 | 07:48 PM
sidewayz28's Avatar
i went to a dynoday and my cars AFR was avg. of 12.1 AFR and max was 12.5 that is lean correct?
