PIN remover?
Old Jan 25, 2007 | 08:59 PM
91_RS_LS1's Avatar
Default PIN remover?
I am planning my LS1 swap, and I know I will delete a few things from the wiring harness. I want to remove the pins from the PCM instead of just cutting the wires coming from the sensors. Is there a way to safely and effectivly removing them?
Old Jan 25, 2007 | 09:07 PM
Magnus's Avatar
LS1TECH Sponsor
Take the harness off of the PCM. Remove the plastic gaurds from the master PCM connector... Then lift up the little white tabs on the pins you wish to remove and push them through the plug..
Its pretty easy once you see the mechanics of the PCM harness connector.
Old Jan 26, 2007 | 07:20 AM
Doc's Avatar
Doc
Jewelers screwdriver
Old Jan 26, 2007 | 09:21 PM
91_RS_LS1's Avatar
Awesome. Thanks guys.
Old Jan 27, 2007 | 05:49 PM
kossuth's Avatar
I usually use the blade of a sharp knife, but just about anything will work on those tabs.
