Base Running Airflow Hptuners
TIA!
This is the minimum airflow your car needs to maintain idle across various engine coolant temps. Other airflow tables like the throttle cracker and follower use this as the existing "foundation" and they are added on top of this.
i've been thinking of doing that, but since AFR during cold startup is much richer than usual, and there's lot of modifiers involved, it'd be hard to deduce if that's what the car wants. but it'd be a experiment, any takers?
Why does one of my tabled have all zero's in it?
ECT -40 -4 32 68 104 140 176 212 248 284
Gear 22 19 15.2002 12.2002 10.40039 10 10 10 10 10
PN 0 0 0 0 0 0 0 0 0 0
Is it because its an M6?
I wonder if your Excel file will help with yobabiesdaddy2001's tune?
the excel file was made back in days of HPT 1.7, when you couldn't make custom histograms. these days if you want to fix your RAF, just do a STIT vs ECT histogram and then special-paste-add it on top of your corresponding RAF row (just the gear one for M6, you gotta do two separate full cold->full warm passes for A4)
