Dynamic and Maf
Old Jan 26, 2007 | 05:50 PM
yobabiesdaddy2001's Avatar
Default Dynamic and Maf
what is the difference between dynamic and Maf airflow lb/min?
Old Jan 26, 2007 | 06:15 PM
RedHardSupra's Avatar
dynamic airflow is a result of a Speed Density calculation (VE table is the base of it) while MAF is just a lookup from the MAF calibration
Old Jan 27, 2007 | 07:12 AM
makes alot of sense Supra. I am asking as much questions as i can so that i can understand this stuff systematically vs just going through the steps.
Old Jan 27, 2007 | 07:43 PM
I am about to configure a histograhm so I can log dynamic airflow vs Eng. Coolant Temp.
Then I will copy and paste the values that I gain to the base running airflow table.
Think it will work?
Old Jan 27, 2007 | 10:36 PM
depends, what are you trying to do? RAF? i prefer to do RAF from STIT vs ECT histogram, i just did it on a 240+ duration cammed car and got it perfect in 2 scans so it definitely works
Old Jan 27, 2007 | 11:32 PM
yea, I am doing it for base running air flow table. I will loaded it tommorow and see what it does. I will post results.
Old Jan 28, 2007 | 11:25 AM
SSpdDmon's Avatar
MAF values aren't as accurate at low airflow scenarios. That's why the cars use a combo of VE & MAF for fueling under 4,000rpm. You should use the STIT+LTIT as suggested (multiple times).
