can u use mutiple tuning programs on the same PCM?
Old Jan 28, 2007 | 01:57 PM
2002/Black/SS's Avatar
Default can u use mutiple tuning programs on the same PCM?
my tuner is gonna tune my car with HPtuners and i have EFIlive. after he tunes it can i just plug in my efilive and change more stuff? will it lock the pcm or anything?
Old Jan 28, 2007 | 02:04 PM
foff667's Avatar
LS1TECH Sponsor
as long as your tuner doesnt use one of our custom operating systems or locks your computer you should be fine tuning with efilive.
Old Jan 28, 2007 | 02:21 PM
does 2bar SD count? oh i get it, if he tunes with ur 2BAR SD then i cant change it with EFIlive 2BAR SD.
but if he tunes it with ur 2BAR SD, then can i still change anything with EFIlive???
Old Jan 28, 2007 | 02:41 PM
foff667's Avatar
LS1TECH Sponsor
if he uses ANY of our custom operating systems YOU will not be able to edit them via efilive...we use completely different tables/OS's then efilive does.
Your tuner would need to do a 1 bar tune witht he stock OS for you to be able to modify anything.
Old Jan 28, 2007 | 03:17 PM
kbracing96's Avatar
Why don't you have your tuner do your tune with your efilive, then you can still tune it after he gets done? If he is worth his salt, then he will be able to tune with any software, as the fundamentals are the same, it's just a different interface.
Old Jan 28, 2007 | 04:15 PM
foff667's Avatar
LS1TECH Sponsor
thing is with a 2 bar HP Tuners custom Operating system he could use our Real Time Tuning which is a huge time saver...not to mention efilive is completely different to navigate through as well as make maps with...time wise I could see it not being worth it for the person tuning his car to use efilive.
Old Jan 28, 2007 | 04:24 PM
Geoff's Avatar
Read the above post. Lots of tuners use both interfaces. Even if he is used to exclusively using HP Tuners, it shouldn't be a huge jump to use EFI Live.
Old Jan 28, 2007 | 04:25 PM
well ill ask him
