Cold start and KR help with HP Tuners
Old Jan 29, 2007 | 01:09 AM
blu98ta's Avatar
Default Cold start and KR help with HP Tuners
I am having a problem getting my car to stay running on start up without keeping my foot in the gas. What do I need to mess with to fix this? I can't seem to save a log to upload for yall. Also I wanna say that knock retard between 2800-3600 was over 10 and the car bogged like crazy. Then all the sudden at 4k the car would really come alive. WTF?
Brandon
Old Jan 29, 2007 | 09:01 AM
jimmyblue's Avatar
Moderator
Scan > Save_Data_As to save log files
Raise the base running airflow to about the value of
Dynamic Airflow you see with the throttle held to
where you have the right RPM, at the ECT of the
moment. You can populate the table that way as a
start and then refine it by idle trims. Using Excel (or
the StarOffice freebie equivalent) may be easier for
picking off datapoints by eye.
I suspect the VE table is messed up by the mods
(although too, extremely ported heads may aggravate
fuel mixing at lower RPM and worse yet in cold weather
/ cold motor where the fuel does not vaporize so well).
This is suggested by how it "comes alive" right about
where Dynamic Airflow cuts over to all-MAF basis.
Although the '98s -do- come with extra-fussy knock
sensors as a first-year bonus....
Old Jan 29, 2007 | 11:36 AM
blu98ta's Avatar
So if i save a log file can yall look at it for me?
Old Jan 29, 2007 | 03:01 PM
blu98ta's Avatar
What can I do about the knock retard? CAn I change the values to make the knock sensors less sensitive without hurting the motor? Any help would be awesome guys
Old Jan 29, 2007 | 06:50 PM
jimmyblue's Avatar
Moderator
If you have never changed them out for the new P/N
('99-up) it's worth a blind stab (or two).
You can attach log files on this 'board and on HPTuners'.
People may tell you "shoulda logged this & that", but
start with what you've got and then roll with it.
