crank sensor??
Old Feb 1, 2007 | 10:58 AM
Proto X's Avatar
Default crank sensor??
It is a 98 formula. Problem is no codes. It idles like it has a mis and smells like gas. It is like it is flooded. When it dies it takes a couple times to get it started. I have done plugs, wires, injectors, coils, checked fuel pressure, compression is good. What is the problem???
Old Feb 2, 2007 | 03:05 PM
Blades's Avatar
Mine ended up being a bad ground... Sounds like yours is too.. You need to give it time for the charge to dissipate and then it will start up? Change your plugs as they are probably fouled out by now.
