83% throttle at WOT
Old Jan 23, 2007 | 10:13 PM
TchargedLS1TA's Avatar
Default 83% throttle at WOT
Anyone know why my LS2 is only going to 83% max at WOT?? Tq management is all turned off (I think).
Also at .68 g/cyl, my spark advance hits 0* for about 200 rpm from 1400-1600
Old Jan 23, 2007 | 10:28 PM
ChrisS@sdpc's Avatar
Is this in the Trailblazer? Have you confirmed the actual travel of the TB?
Old Jan 23, 2007 | 11:09 PM
MeentSS02's Avatar
Kleeborp the Moderator™
Electronic throttle or cable driven?
Old Jan 24, 2007 | 06:31 AM
Billiumss's Avatar
Check to see if your floor mat is in the way of the gas pedal. I have seen this on a few F-Bodys.
Old Jan 24, 2007 | 07:38 AM
Sneakyws6's Avatar
On the tree
Pull the inlet tract into the throttle body so that you can see the throttle blade. Have someone go in and push the throttle to the floor and make sure the blade is open all of the way and that the throttle body cam is sitting on the stop.
If it is not make sure the floor mat is out of the way and that there is nothing binding the cable or throttle cam. If everything is clear then check the TPS sensor and make sure it on correctly. The computer gets it % reading directly from this sensor, if it is bad it could cause a false reading to the ECM.
Old Jan 24, 2007 | 07:39 AM
NoMoreFWD's Avatar
83% is normal on fly by wire throttle body. I would have to look into the spark advance.
Old Jan 24, 2007 | 07:42 AM
foff667's Avatar
LS1TECH Sponsor
Depending on which software your using GM decided to change the PID used for throttle position...if your using HP Tuners just log ETC Desired Position % rather than the old Throttle position SAE.
Old Jan 24, 2007 | 03:20 PM
Here's my data log from last night
Old Jan 25, 2007 | 03:12 PM
pdanrichey's Avatar
I've seen what you're talking about on auto cars...mainly the Vette's that have the electronic TB. Not sure about the spark advance though...
Old Jan 26, 2007 | 03:12 PM
foff667's Avatar
LS1TECH Sponsor
Here's the skinny that i can see on the advance, BUT he didnt post his file so who knows, but looking at the 06 TBSS file I DO have in the 1200rpm cell that he sees 2* of timing the high octane table is commanding 4* on its own BUT with his IAT temps @93* the stock IAT table would be pulling out ~5* of spark advance so if ANYTHING that 2* of advance he is getting is more then is being COMMANDED with the stock file I have.
Look at the log
Look at the histograms
match it to the corresponding tables
you'll then find your answers
Old Jan 26, 2007 | 03:45 PM
Frost's Avatar
edit
doh! nvrmnd
Old Jan 28, 2007 | 02:48 AM
Blades's Avatar
Same deal with mine. You need to look at ETC.. thats the real deal.. Never seen above 84 on TPS.. Usually 83 and then briefly to 84 and back down to 83. However, I have a problem with my trans temps showing up as 32 degrees. Whats with that?
Old Jan 29, 2007 | 12:37 AM
2MuchRiceMakesMeSick's Avatar
whats going on with the speedo in that log?
It doesnt update until you get to 90mph
Old Jan 29, 2007 | 04:51 AM
Slowhawk's Avatar
LS1Tech Sponsor
The 83% is normal on the scanning.I've confirmed that they are 100% at that time.Just a PID thing for LS2's.
Old Jan 31, 2007 | 05:18 AM
onecamaro1's Avatar
Ive noticed mine at 80%, and i found the culprit. A plastic block off plate bolted behind the gas pedal, i'll take it off this weekend.
Old Jan 31, 2007 | 06:39 AM
Slowhawk's Avatar
LS1Tech Sponsor
Your kidding right? On ETC cars that is a stop so the peddle doesn't go to far.
Old Jan 31, 2007 | 10:35 AM
onecamaro1's Avatar
Wink
This is a 2001 camaro ss m6. Just put ls6 conversion heads and cam. I noticed 80% on efi live and started to investigate. The throttle does not hit the stop, and i saw the stopper on the pedal. ETC is fly by wire, right? I have an actual cable.
Old Jan 31, 2007 | 10:48 AM
Xtnct00WS6's Avatar
I had a similiar problem. I was getting around 90ish% and my problem ended up being the throttle cable needed to be adjusted. For those that don't know...you can't actually adjust the cable by the plactic connector thing halfway up the cable.
Old Jan 31, 2007 | 11:10 AM
onecamaro1's Avatar
I'll go look right now....Man it's cold outsi de.
Old Jan 31, 2007 | 11:38 AM
onecamaro1's Avatar
Back, i see the 2 clips on the cable (one before the round can and one on the cable after the can), i will do it tomorrow after work. Thanks.
