For those of you who live in cold climates...
Any insights?
Thanks.
"Heater circuit" means you have either a short or a broken cable between the PCM and the heating resistance of the O2 sensor.
Maybe it happens when it's cold because of humidity. Do you have salt on your roads? Have you inspected the O2 cables and connector?
You can swap your actual sensors right to left and see if the error changes from one bank to the other. If not it's the cable
Yes, I need to look at the sensor and cable to check their condition (I see that the heater is also fused, so maybe I can get away without crawling under the car this weekend!
).I was also looking at this as an opportunity to replace that sensor with a WB. Of course, you know how cheap I am, so I doubt I'll find anything on my $40 budget.
How's everything going in your neck of the woods?
Not too bad over here! Still too much work, but so far I'm surviving
Hopefully, you're staying warm. It's about -13C here at the moment.
