MAF question ???
my car it Modified so i want to a dvice naw
i keep the maf or remove ?
thank you for advice
navy
Don't confuse SD with Open Loop (OL). Speed Density is a strategy to calculate airflow (or engine load). Open Loop is function of whether or not the PCM is receiving feedback from the O2 sensors. You can operate the engine in SD mode under Open Loop or Closed Loop.
You might want to read this for HPTuners Custom OS's. Here is a longer description of operating modes and feedback methods.
You'll better go with a newer PCM, 2 bar MAP and a program capable to handle it.
You'll need some rewiring too (the pin's are different)
and what do you think remove or not
