Heeelpp!!
Old Feb 10, 2007 | 06:55 PM
RUSTYTA's Avatar
Default Heeelpp!!
im throwing these three codes (p1153, p1133, p0133)..gearchatter.com says that when 1153 and 1133 are intiated together then more than likely i have a fuel contamination problem...what could have caused this and how do i fix these problems....car is running like dogshit!
Please help, thanks in advance
Old Feb 10, 2007 | 07:35 PM
ZL1Killa's Avatar
well 1153 and 1133 are just o2 switching insufficiently. don't know about p0133. look it up on here. what all is done to the car? how many miles on it?
my best suggestion is possibly get new 02's and disconnect the battery and then reconnect it to reset everything. then see how it is.
Old Feb 11, 2007 | 03:37 PM
Karpellarpy's Avatar
leaded gas will kill a pair of O2s. Someone correct me if I'm wrong, but I believe the pcm drops into open loop when those codes are thrown. If you have significant mods, then the open loop tune wont be anywhere close to right, and since the pcm isn't using any of the fuel trims, then it'll run like pooh.
Old Feb 11, 2007 | 11:20 PM
RUSTYTA's Avatar
karpellarpy i think this is exactly what happened....but i already put the new o2s on and it ran better for like a day or two but now it runs worse than before....how do i fix these problems? retune?
yes its heads/cam and full boltons 422/399...so yes significant amount of mods...
Old Feb 11, 2007 | 11:26 PM
ZL1Killa's Avatar
how/where did u get a hold of leaded gas?
