who can take a look at this lt1 data log?
Old Feb 10, 2007 | 09:33 PM
Mr_president's Avatar
Default who can take a look at this lt1 data log?
well my buddys car is all jacked up and i would like to email the data logs we took today and have someone tell me what is going on why his car is a turd....
its a 383 stroker lt1 also it is very rich!
Old Feb 10, 2007 | 09:40 PM
here are the files
File Type: zip
File Type: zip
Old Feb 11, 2007 | 08:42 AM
koolaid_kid's Avatar
What tuning app are you using? I use LT1Edit, but cannot open the file.
Old Feb 11, 2007 | 11:12 AM
2xLS1's Avatar
They are Datamaster files.
Idle data: Drivers side O2 sensor seems to be stuck around 4xx~5xx mv instead of switching high/low like the pass side. You might try swappin O2s L to R and see if it follows the sensor.
Data run: Car has constant 5 degrees KR as soon as you go WOT. Other than that, it doesn't look too bad. You need to give a lot more info on the car, mods, and if any changes have been made in the tune. Is this an OBD2 -> OBD1 conversion by any chance?
Old Feb 11, 2007 | 01:26 PM
this is not an ob2>ob1 conversion. the car is a 388 storker with a stall 3200 373 gears we think 36 pound injectors.....missifires like crazy buck and bucks and is slow as hell, it made 300 hp an 300 wrt at 10.0 a/f....my buddy doesn't think that the left and right o2's ground is hooked up(little black wire behind the starter next to the knock sensor...
