Stock or Modified VE table
You are probably finding its rough until it goes into closed loop.
IMO you should retune (not scale) the VE to match the engines new VE. Thats exactly what the VE table is for!
If your engine changes why wouldnt you change it?
There's a reason this guy's banned on many boards (this one included) (that's not to say that all the info he's posted is useless.... it's just more of his posts are comical than useful)
One thing to keep in mind witha big cam and the fuel trims... w/a big cam there's alot of overlap... so for the most part wideband and even narrowband readings can't be trusted... even w/the ideal fuel mixture, because there's a short period of time where both the valves are open, there will be some raw fuel pushed out into the exhaust stream... plus between 400 and 1200 RPM , power isn't necessarily the important thing... you tune the car to idle... when racing that's not even part of your powerband (dunno if I've ever even seen a dyno for a car starting that low of RPM... other than hypercrap and such which use power gains at low RPMs as a marketing gimick)
Regardless of the method used, the end result is only as good as the tuner
If you want your car tuned correctly, you need to have your VE table tuned via a WB 02 within 2% and then tune the MAF table within 2%
there's a wonderful thread on monodax's forum where he makes 'physics based' claims that contradict each other, and then he proceeds to bash people and companies by name only because they don't agree with what he thinks is physics. i dunno who pissed in his cheerios, but as a businessman i thought you supposed to be nice to people.
i know i make a lot of fairly out there statements (just like zr1 does), but because of it, i try to back it up with hard science, and provide full derivation for everything i do. partially to show i have nothing to hide, partially because i'd love to have someone double check my work. so far i haven't had any big 'oops i was wrong' moments yet. until he can explain to me how car mods do not affect VE, or how MAF should not be altered when you change the air tract, i'm sticking to my version of things.
what really pisses me off is his 'we know already everything there is, thus everything new must be wrong' approach. it's thinking like this that threw Galileo in jail and tried to force Copernicus to recant his ideas.
<rant off>
Actually, the Vortec trucks with the black boxes do use the VE tables, and cams or big cubic inch trucks do benifit from working with the VE tables. However, the kids that have decided the VE table needs to be a pretty graph, or smoothed, simply don't know what they are talking about. They need to graph a stock VE table, and tell us how pretty and smooth it is. Guess the GM calibrators don't know what they are doing, right? Unless it is a big stroker, I don't see much value is changing LS1 and later VE tables. The 2 factory calibrators I'm aquainted with get a kick out of the guys trying to tune VE tables with a wide band. They both read ls1tech pcm section "for grins". Those kids want to treat a factory PCM like a DFI, etc. They don't seem to realize the GM boxes toggle the air/fuel rich/lean/rich/lean many times a second to store oxygen in the cats. Confuses the hell out of the wide band, all it can do is try to everage the numbers. The values it gives is inacurate, so then when they hook the MAF back up and put it back into closed loop the MAF tables must be wrong too because the fuel trims are now off. Pretty damn comical.
I'd like to ask him, "So if the Car doesn't have CATs, is the WB accurate then?" lol
but to add to this, i've also completely derived the Speed Density model, which greatly enhanced my understanding on why we _need_ to change VE.
but beyond all the technobabble, there's also just simple common sense: why are we exchanging parts for bigger, smoother, mandrel bent, etc? where does power come from? in NA motor, you have fixed displacement, RPMs are limited by reliability, and pressure goes up only up to the atmospheric. the only other ways of improving airflow is to either lower temperatures (aka increase density which squeezes more mass into the same volume) or to improve VE. the reason why leaving VE stock is ridiculous to me, is the nature of aftermarket parts and how they affect the system. LT's greatly improve midrange. most big cams trade off low end for high end (efficiency wise). heads usually improve through the full range, but more toward the high end. there is no easy way to describe all the different VE changes across various RPM and MAP conditions, other than the VE table. (this gets much complicated these days with variable lift/duration cams and other high tech gizmos, but that's a totally different discussion)
PE/IFR tweaking, ever so popular with the oldschool guys, describes only a subset of VE. PE is RPM based and IFR is MAP/ManVac based, so if you put them together you end up with a similar functionality to VE. their downfall however is that they only describe proper fueling for _one_ row/column of VE, while VE proper is an actual table, with all values filled out. therefore, unless your IFR table has one value across the whole table (and it doesn't unless you have a really kickass fuel system), and your airflow is directly proportional to RPM only, without any swings in efficiency, IFR/PE tweaking is a 'tune' for one and only one situation--until recently such 'tuners' been able to get away with it, as the domestic crowd is interested in WOT only, and lousy drivability is called 'lope' and 'drive-in sound' and is somehow considered cool.
so yes, IFR/PE tweaks have their place--if i had to tune a track only drag car and had 5 minutes to do it, i'd probably use this method and not feel too guilty about it. however, if that's all there's required of you, WOT performance and no drivability concerns, a carb would provide better atomization and it would be a much cheaper solution.
that's what i see PE/IFR tweaking as--carb tuning for people who are forced to deal with EFI.
to deny the fact that VE changes with mods is equivalent to deny that mods change VE. since that's the whole goal of modding, i'd say that's a bunch of horsepoo. we mod, we get more airflow, we make more power, and since there's only that many ways to achieve that out of a NA motor, VE must change.
Nuff said.......
And as far as Ed Wright comparing GM hardware to DFI, well, they are at their core, both sequential, feedback systems, based on most all the same principals. So tuning a GM PCM "like they're DFI" isnt too far off base.
Never seen PE tuning cure ANY cam driveability problems. OR idle problems.
That being said, the closer the VE table is to correct, the LESS PE needed to achieve a given A/F ratio
The VE needs to be tuned if you want a car that performs well on a consistent basis. Stop looking at it in terms of theoretical percentages and look at it in the default units: ((Grams*Kelvin)/kPa) That to me says that the engine can flow 'x' amount of air with a given MAP pressure at a given charge temperature. Modding a motor is often described (in the most basic terms) as improving it's ability to breathe. Whether you do that with headers, an intake or a camshaft, you're increasing that VE number as the engine breathes easier. In terms of some mods like a camshaft, this may not be true across the board though. A stock camshaft can breathe easier at say 600rpms because of it's design. That's why it is represented with a higher VE - because it requires more fuel to maintain a 14.63 AFR at that RPM. Aftermarket cams don't require that much fuel because the amount of air they can deliver at that same 600rpms isn't as great. Therefore, they require a lower VE value, which translates into less calculated fuel delivered to the cylinders.
The problem mentioned above about the engine cycling rich/lean every second only pertains to closed loop. Granted, you can get a VE very close using narrowbands in closed-loop operation. But, that will only work for ~75% of the table. WBO2's aren't thrown off as claimed above because we tune in open loop. There's no need for the PCM to cycle the AFR because the NBO2's aren't doing **** in open loop.
All in all, believing half of what you see and less of what you read on here is a good approach to learning. So take it with quite a few grains of salt...
