2 questions regarding LS2 Edit
Old Feb 13, 2007 | 07:55 AM
98Z28CobraKiller's Avatar
Restricted User
Default 2 questions regarding LS2 Edit
I have a friend that bought LS2Edit to tune his new Z06. I took a look at it for the first time last night. I have 2 questions:
1) Is there a VE table?
2) Where is it located or by what name does it go cause I couldn't find it?
I couldn't even find an Airflow tab. I found the fueling tab which had the injector offset, inj slope?, MAF Hig and Low, and the PE table.
I use HPTuners so I am familiar with what does what, just can't find it in the software.
Also, if anyone knows, can you log with LS2edit or do you need a different scan tool like Autotap?
Old Feb 13, 2007 | 08:23 AM
foff667's Avatar
LS1TECH Sponsor
there is no standard ve table in a ZO6...this at least 1 new zo6 file to peak through on our repository if you'd like to compare.
Old Feb 13, 2007 | 09:59 AM
Restricted User
I will check it out. So how do you dial in the AFR Error? Is it MAF only?
Old Feb 13, 2007 | 12:12 PM
foff667's Avatar
LS1TECH Sponsor
unless someone figures out a different way at some point & decides to share, yes.
