Fuel pump & tach issues- 1998 PCM
Old Apr 15, 2007 | 05:09 PM
V8 Supra Builder's Avatar
Originally Posted by David Borden
You ever solve the fuel pump relay/VATS problem? A bunch of FFR GTM builders are experiencing the same type of challenges. I know that John from Speartech has been helping a few of them with new ECU's and harnesses.
Speartech nailed the problem immediately- I had the PCM wire going to the wrong terminal on the fuel pump relay. VATS was not the issue.
